Dell Inspiron E1705 Battery Replacement
  1. Dell Inspiron E1705 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Dell Inspiron E1705 Battery Replacement: шаг 2, изображение 1 из 2 Dell Inspiron E1705 Battery Replacement: шаг 2, изображение 2 из 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
Заключение
To replace your battery, follow these instructions in reverse order.
5 участников успешно повторили данное руководство.
Malik Shahbal
Участник с: 10/05/10
471 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 22-5, Maness Fall 2010 Участник Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 членов
Автор 11 руководств
Один комментарий
I think it would be complete if we knew where to buy it as well.
Nobody would read up on changing a battery if he didn’t need one, so you might as well tell him where to get it.
I think that makes sense. However thank you for your effort.
kjanmunkedal - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 4,242
