Введение
Please read the troubleshooting section before using this repair guide to take apart your computer. Many problems can be resolved without taking the computer apart.
It is important to remove the battery before following these instructions. It will ensure no electrical discharge to occur. If you are unsure at all about how to remove the battery please refer to the battery repair guide for this item.
  1. Make sure that the computer is turned off and is disconnected from external power source.
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
    Introduction: Parts: Need to add the Fan Part Numbers
    Original equipment: CPU Fan DC28A000820, GPU Fan DC28A000920
    John Frazier - Ответить
  2. While holding the switch in the open position, lift out the battery. If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Turn the computer over, screen closed, so that the underside is showing Locate the two screws as shown and remove them.
    • Turn the computer over, screen closed, so that the underside is showing
    • Locate the two screws as shown and remove them.
    • Use a small phillips head screwdriver
  4. Remove plastic cover carefully There will be two RAM sticks as shown Using your fingers, pull the sides apart that are holding the RAM in place.  This will release the RAM.
    • Remove plastic cover carefully
    • There will be two RAM sticks as shown
    • Using your fingers, pull the sides apart that are holding the RAM in place. This will release the RAM.
  5. Carefully remove old/damaged RAM sticks and replace with new ones.
    • Carefully remove old/damaged RAM sticks and replace with new ones.
Заключение
5 участников успешно повторили данное руководство.
Evan Fairchild
Участник с: 05.10.2010
601 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 22-5, Maness Fall 2010 Участник Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 членов
Автор 11 руководств
Один комментарий
If upgrading RAM, a black DOS based screen will show stating "the amount of RAM in system has changed", wait 1minute and the computer will beep and prompt for F1 (boot normally) or F2 (run system setup utility). Pressing F2 and waiting some time will allow the computer to reconfigure and then boot into Windows normally.
bejtommywy - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 7,978
