Dell Inspiron M5010 Display Assembly Replacement
Выберете то, что вам нужно
  1. Dell Inspiron M5010 Display Assembly Replacement, Remove the Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over and remove the two screws.
  2. Dell Inspiron M5010 Display Assembly Replacement, Disconnect the Cables: шаг 2, изображение 1 из 1
    • Disconnect the Mini-Card antenna cables from the Mini-Card.
  3. Dell Inspiron M5010 Display Assembly Replacement, Disconnect the Display Cable: шаг 3, изображение 1 из 1
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
  4. Dell Inspiron M5010 Display Assembly Replacement, Remove the Screws: шаг 4, изображение 1 из 1
    • Remove the four screws (two on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron M5010 Display Assembly Replacement, Lifting the Display Assembly: шаг 5, изображение 1 из 1
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron M5010 Display Assembly Replacement, Placing the Display Assembly: шаг 6, изображение 1 из 1
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron M5010 Display Assembly Replacement, Route the Display Cable: шаг 7, изображение 1 из 1
    • Route the display cable into the routing guide and connect the cable to the connector on the system board.
  8. Dell Inspiron M5010 Display Assembly Replacement, Connecting the Mini-Card Antenna Cables: шаг 8, изображение 1 из 1
    • Connect the Mini-Card antenna cables to the connectors on the Mini- Card.
  9. Dell Inspiron M5010 Display Assembly Replacement, Replace the Screws: шаг 9, изображение 1 из 1
    • Turn the computer over and replace the two screws at the bottom of the computer.
Финишная черта
Еще один человек закончил это руководство.
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 8
За всё время: 186
