Введение
In this guide, you will learn how to replace the processor in the Dell Inspiron M5030. To remove, clean off, and replace the thermal paste in order to remove the heat sink, please refer to the Applying Thermal Paste Guide.
Запчасти
Никакие детали не требуются.
  1. Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop. Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
    • Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
    • Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
  2. Turn the laptop over and open the lid. Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
    • Turn the laptop over and open the lid.
    • Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
    • With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
    • Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
    • Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
  3. After the top edge of the keyboard is loose, pull up on the keyboard gently. Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by  a ribbon.
    • After the top edge of the keyboard is loose, pull up on the keyboard gently.
    • Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by a ribbon.
  4. Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard. Locate the blue end of the ribbon which is connected to the motherboard. Lift up the black flap on the connector and gently pull the ribbon away from the connector  which is parallel to the motherboard.
    • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
    • Locate the blue end of the ribbon which is connected to the motherboard.
    • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
    • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
  5. Disconnect the blue tab located just above the touch pad of the laptop. Disconnect the blue tab located just above the touch pad of the laptop.
    • Disconnect the blue tab located just above the touch pad of the laptop.
  6. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  7. Use a plastic opening tool to pry up the plastic covering of the laptop by wedging it underneath one side of the covering and lift up. Do not lift off the cover all the way as it is still connected by two wires on the side nearest to the screen.
    • Use a plastic opening tool to pry up the plastic covering of the laptop by wedging it underneath one side of the covering and lift up.
    • Do not lift off the cover all the way as it is still connected by two wires on the side nearest to the screen.
  8. Disconnect the white block of wires which is  the right-most wire connecting the covering to the laptop. Disconnect the white block of wires which is  the right-most wire connecting the covering to the laptop. Disconnect the white block of wires which is  the right-most wire connecting the covering to the laptop.
    • Disconnect the white block of wires which is the right-most wire connecting the covering to the laptop.
  9. Disconnect the wire with the blue tab which is the left-most wire connecting the covering to the laptop. You can now remove the plastic covering. You can now remove the plastic covering.
    • Disconnect the wire with the blue tab which is the left-most wire connecting the covering to the laptop.
    • You can now remove the plastic covering.
  10. Remove the tape from the fan, but do not remove the tape from the wire. Move the wire away from the fan. There are ridges along the top of the fan which indicate where the wire should sit when you put the fan back.
    • Remove the tape from the fan, but do not remove the tape from the wire.
    • Move the wire away from the fan.
    • There are ridges along the top of the fan which indicate where the wire should sit when you put the fan back.
  11. Locate the yellow/black/red wires and find the white plastic block where they end.
    • Locate the yellow/black/red wires and find the white plastic block where they end.
  12. Using two fingers (one on either side of the block) or two plastic opening tools (one on either side of the block), pinch the bottom of the block and lift up to remove the block. Using two fingers (one on either side of the block) or two plastic opening tools (one on either side of the block), pinch the bottom of the block and lift up to remove the block.
    • Using two fingers (one on either side of the block) or two plastic opening tools (one on either side of the block), pinch the bottom of the block and lift up to remove the block.
  13. Unscrew the four screws from the heat sink with a Phillips #0 screwdriver. You do not need to remove the screws completely from the heat sink. You do not need to remove the screws completely from the heat sink.
    • Unscrew the four screws from the heat sink with a Phillips #0 screwdriver.
    • You do not need to remove the screws completely from the heat sink.
  14. Remove the the black screw above the processor with a flathead screwdriver. Remove the the black screw above the processor with a flathead screwdriver. Remove the the black screw above the processor with a flathead screwdriver.
    • Remove the the black screw above the processor with a flathead screwdriver.
  15. Grab the sides of the processor with your thumb and forefinger to remove the processor. Grab the sides of the processor with your thumb and forefinger to remove the processor. Grab the sides of the processor with your thumb and forefinger to remove the processor.
    • Grab the sides of the processor with your thumb and forefinger to remove the processor.
Заключение
5 участников успешно повторили данное руководство.
Jenine Quintana
Участник с: 17.04.2014
419 Репутация
1 Guide authored
Команда
Cal Poly, Team 3-44, Maness Spring 2014 Member of Cal Poly, Team 3-44, Maness Spring 2014
CPSU-MANESS-S14S3G44
4 членов
Автор 6 руководств
Один комментарий
Is this the right part number for a cpu replacement for a dell inspiron m5030: PART # 3PDDV?
desertsun15 - Ответить
Просмотр статистики:
За 24 часа: 0
За 7 дней: 13
За 30 дней: 35
За всё время: 5,805
