Введение
I am going to explain how to remove the palmrest of the laptop to reach its main board, and other components.
Выберете то, что вам нужно
Slide both of the battery release latches on the bottom of the device in towards the center of the computer.
Lift and slide the keyboard towards the screen to remove the tabs on the keyboard from the slots on the palmrest.
Flip the keyboard over and place it on the front of the device making sure not to pull out the keyboard cable.
Lift up the connector latch and remove the keyboard cable. The keyboard is now free from the device.
Turn the computer over and remove the six screws that secure the palmrest assembly
Turn the computer over and open the display as far as possible and remove the four 5 mm Phillips # 0 screw holding the palmrest in place.
Disconnect the power button board cable, touch pad cable and the hot key board cable from the connectors.
Use a plastic opening tool to carefully pry out the palmrest assembly and lift it off the computer base.
Еще один человек закончил это руководство.
