Введение
Step by step instructions on how to locate and remove screws and parts of the device to locate the screen, remove it, replace it with a new one, and put the device back together.
Выберете то, что вам нужно
Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
Carefully remove the plastic casing from the device.
Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
Carefully unplug the ribbon on the back of the screen.
Place the new screen onto the device and plug the ribbon in.
Replace the screws on the side of the screen.
Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
Turn the computer over and put the battery back in.
To reassemble your device, follow guide instructions.
2 участников успешно повторили данное руководство.
