Введение
In this guide, we will be showing you how to remove and replace the Display Assembly.
Запчасти
Никакие детали не требуются.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in  Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the computer base.
  2. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
    • Disconnect the display cable from the connector on the system board, and remove the display cable grounding screw.
    • Make a note of the Mini-Card antenna cables and display cable routing and remove the cables from the routing guides.
    • Hold the display assembly in place and remove the four screws that secure the display assembly to the computer base.
    • Lift and remove the display assembly out of the computer base.
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
    • Route the Mini-Card antenna cables and display cable through the routing guides.
    • Connect the display cable to the connector on the system board, and replace the display cable grounding screw.
    • Close the display and turn the computer over.
    • Replace the two screws that secure the display assembly to the computer base.
Финишная черта
Terrence15
Участник с: 18.12.2017
70 258 Репутация
Автор 442 руководств
Команда
Informative Technologies Inc. Member of Informative Technologies Inc.
Community
15 членов
Автор 925 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 1
За 30 дней: 2
За всё время: 33
