Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show you how to completely remove and replace the fan on your Dell Inspirion 14R. It requires a bit of patience to accomplish. Replacement of the single internal fan can cause your laptop to run less hot as it is responsible for keeping everything inside the laptop, especially the CPU, cool.
Выберете то, что вам нужно
While holding the left-hand switch to the left position, pull the battery away from the laptop.
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
With a plastic spudger, pry away the silver top cover from the black casing.
Move the tool to the right and left along the seams to fully disconnect the cover.
Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
Peel back the yellow tape to expose the ribbon connector.
Unplug the ribbon cable from the motherboard.
