Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Unlock the battery by sliding the right-hand switch to the right.
While holding the left-hand switch to the left position, pull the battery away from the laptop.
The battery is now fully removed and the laptop will not power on without it.
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
With a plastic spudger, pry away the silver top cover from the black casing.
Move the tool to the right and left along the seams to fully disconnect the cover.
Disconnect the indicated ribbon cables underneath where the keyboard sits.
Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
Peel back the yellow tape to expose the ribbon connector.
Unplug the ribbon cable from the motherboard.
Unscrew the indicated 5.6mm screws with the #0 Phillips Head Screwdriver.
