Введение
Replacing the Hard Drive for a laptop can speed it up and add more storage. Keep in mind that after replacing the hard drive you must reinstall your Operating System. Locate all product keys needed before performing this guide.
Запчасти
Детали не указаны.
While holding the left-hand switch to the left position, pull the battery away from the laptop.
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
With a plastic spudger, pry away the silver top cover from the black casing.
Move the tool to the right and left along the seams to fully disconnect the cover.
Lift the cover upwards and away from the body of the laptop, after removing the optical drive and unscrewing the three screws on the right
Peel back the yellow tape to expose the ribbon connector.
Unplug the ribbon cable from the motherboard.
Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
Unplug the speaker connector from the motherboard.
The motherboard can now be removed by pulling upwards, tilting it to the left of the laptop until the connectors clear the body of the laptop.
Unscrew the 6 Phillips head screws holding the hard drive to the motherboard with the #0 driver head.
Slide the hard drive towards the center of the motherboard.
The hard drive should come away from the motherboard.
Undo the 2 screws with the #0 Phillips head driver on either side of the hard drive assembly.
3 участников успешно повторили данное руководство.
Комментариев: 6
I hope somebody at Dell lost their job over this design.
hahaha i agree
Robert G -
The N4010 is definitely a beautiful-looking set, but it’s sure a tough nut to crack when it’s time to repair something inside it, lol :-D
A bunch of screws not listed have to be removed also they are in proximity of the cmos battery I imagine someone will damage their machine following this NOT GOOD! I signed up just to post this! Look for screws with the LETTER B they need removing before the board can come out! ifixit should screen their submissions better
In step 20 we remove the screws
