Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
In this guide, we will be showing you how to remove and replace the Hard Drive.
Выберете то, что вам нужно
Remove the two screws that secure the hard-drive assembly to the system board.
Slide the hard-drive assembly to disconnect it from the connector on the system board.
Lift the hard-drive assembly away from the system board.
Remove the four screws that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive and replace the four screws.
Slide and push the hard-drive assembly to connect it to connector on the system board.
Replace the two screws that secure the hard-drive assembly to the system board.
Еще один человек закончил это руководство.
