Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Unlock the battery by sliding the right-hand switch to the right.
While holding the left-hand switch to the left position, pull the battery away from the laptop.
The battery is now fully removed and the laptop will not power on without it.
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
2 участников успешно повторили данное руководство.
