Введение
Replacing the screen is a lengthy process that can take a while. It is important you are gentle with the screen as it can be damaged quite easily. Additionally, the screen should be disposed of according to local laws.
Выберете то, что вам нужно
Using the #0 Philips head, unscrew the screen bracket from the base of the laptop.
Remove the plastic seal located on the back of the screen to expose the ribbon connector.
Unplug the ribbon cable from the screen.
Use the #0 Philips head to remove the six screws on either sides of the screen frame.
Remove the metal frame from the screen.
2 участников успешно повторили данное руководство.
