Введение
This guide helps replace the fan if the computer is overheating. This will require a fan replacement.
Выберете то, что вам нужно
Locate the battery on the underside of the laptop.
Push the two battery clips following the direction of the arrows.
Pull battery away from computer until it is fully removed.
Flip the computer over, and open the laptop.
Use a plastic opening tool to begin to remove the keyboard.
Use your hands to finish separating the keyboard from the laptop.
Lift the black clip from the tan connection for the keyboard.
Pull the the connection away from the clip.
Move the keyboard away from the laptop.
Lift the black clips from the tan connections for all 3 locations marked.
Remove the connections from the clips.
Use plastic opening tools to remove base cover.
Use your hands to fully remove cover from the base.
Disconnect the ribbon cable over the screw to reveal it. Flip up the latch and pull gently on the ribbon to remove it from the connector.
Unscrew the 2.5x5 mm screw from the fan.
3 участников успешно повторили данное руководство.
