Введение
Is your motherboard damaged or are you looking for an upgrade? if so, this guide will show you how to locate and replace a motherboard.
Выберете то, что вам нужно
Locate the battery on the underside of the laptop.
Push the two battery clips following the direction of the arrows.
Flip the computer over, and open the laptop.
Use a plastic opening tool to begin to remove the keyboard.
Use your hands to finish separating the keyboard from the laptop.
Lift the black clip from the tan connection for the keyboard.
Pull the the connection away from the clip.
Move the keyboard away from the laptop.
Lift the black clips from the tan connections for all 3 locations marked.
Remove the connections from the clips.
Use plastic opening tools to remove base cover.
Use your hands to fully remove cover from the base.
Disconnect the ribbon cable over the screw to reveal it. Flip up the latch and pull gently on the ribbon to remove it from the connector.
Unscrew the 2.5x5 mm screw from the fan.
Unscrew the six 2.5x5mm screws from the motherboard.
Note that this screw may be "retained" by the loop at the end of the grounding wire.
2 участников успешно повторили данное руководство.
2 Комментариев
After pulling off the battery, the step to remove the four M2x3 mm screws was forgotten. Please update the guide.
