Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Is your laptop screen cracked or broken? This guide will help you to replace the screen in several easy steps.
Запчасти
Детали не указаны.
  1. Make sure the laptop is off and unplugged before starting this step.
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Push upward from the base of the battery.
    • Push upward from the base of the battery.
  3. Pull battery away from computer until it is fully removed.
    • Pull battery away from computer until it is fully removed.
  4. Use your hands to remove the plastic cover from around the screen. This can seem difficult, but it can be done. This can seem difficult, but it can be done.
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Unscrew the two 2.5x4 mm screws from the top of the screen. Unscrew the two 2.5x4 mm screws from the top of the screen.
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Loosen the four 2.5x4 mm screws from the base of the screen. This will allow the screen to lift from inside the top of the case.
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Unscrew the four 2x3 mm screws from the two sides on both the top and bottom. Unscrew the four 2x3 mm screws from the two sides on both the top and bottom. Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Use tweezers to peel the webcam away from the top of the laptop. The webcam is only held in place by a webcam, this is easy to pull away from the screen.
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Lift the adhesive flap from the cord that connects the computer to the screen. You can then disconnect the cord from the screen. You can then disconnect the cord from the screen.
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. The screen can now be fully removed from the computer.
    • The screen can now be fully removed from the computer.
Заключение
Abigail Keith
Участник с: 20.03.2018
409 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S5-G1, Peak Spring 2018 Участник UMass Dartmouth, Team S5-G1, Peak Spring 2018
UMASSD-PEAK-S18S5G1
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 537
