Введение
In this guide, we will be showing you how to remove and replace the Display Assembly.
Запчасти
Никакие детали не требуются.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over and remove the two screws.
  2. Disconnect the Mini-Card antenna cables from the Mini-Card.
    • Disconnect the Mini-Card antenna cables from the Mini-Card.
    • Disconnect the display cable from the connector on the system board and remove it from the routing guide.
    • Remove the four screws (two on each side) that secure the display assembly to the computer base.
    • Lift and remove the display assembly out of the computer base.
    • Place the NEW display assembly in position and replace the four screws (two on each side) that secure the display assembly to the computer base.
    • Route the display cable into the routing guide and connect the cable to the connector on the system board.
    • Connect the Mini-Card antenna cables to the connectors on the Mini- Card.
    • Turn the computer over and replace the two screws at the bottom of the computer.
Финишная черта
Terrence15
Участник с: 18.12.2017
70 228 Репутация
Автор 442 руководств
Команда
Informative Technologies Inc. Member of Informative Technologies Inc.
Community
15 членов
Автор 925 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 10
За 30 дней: 36
За всё время: 241
