Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will help you if you want to put in a new hard drive or if you have a broken one that you need to replace on a Dell Inspiron N5030.
Выберете то, что вам нужно
Turn the computer over on its back so the battery compartment faces towards you.
Place your fingers on the small buttons with arrows pointing outwards.
Push and slide the buttons outward to unlock the battery compartment.
Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
Position your fingers on two sides of the hard drive in the bottom right corner of the computer.
13 участников успешно повторили данное руководство.
3 Комментариев
It is better and easier to take the keyboard out first to enable safe removal and fitting of the keyboard ribbon cables, Lever panel out once screws are removed as described above. However thanks for the pointers!
The connector in step 7 is actually the connector for the speakers. The keyboard connector is the long white one with the brownish top which appears to be open in the photo. The keyboard cable is a flat wide cable that fits in the connector. In the photograph the keyboard cable has already been removed.
I want to repeat what Charles Mott said. The proper way to do this is to unclip the keyboard providing easy access to all the cable connections. The people that say Dell designed this poorly don’t know they can just unclip the keyboard (three little tabs).
