Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Turn the computer over on its back so the battery compartment faces towards you.
Place your fingers on the small buttons with arrows pointing outwards.
Push and slide the buttons outward to unlock the battery compartment.
Grab the battery and pull it towards yourself.
Remove the battery.
Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
Flip over the laptop and open it so that the screen faces you.
Use the plastic opening tool and your fingers to pry off the top panel.
Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
5 участников успешно повторили данное руководство.
2 Комментариев
What if i broke the blue ribbons connection to the keyboard
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
