Введение
If you want to upgrade your computer by putting in new RAM, or if you need to replace your RAM with new boards, use this guide to learn how to do it.
Выберете то, что вам нужно
Turn the computer over on its back so the battery compartment faces towards you.
Place your fingers on the small buttons with arrows pointing outwards.
Push and slide the buttons outward to unlock the battery compartment.
Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
Pull up on the blue plastic tab connected by the white strip to unhook the keyboard panel from the motherboard.
Flip up the small locking flap on the keyboard cable ZIF socket and disconnect the keyboard ribbon cable.
Pull up on the wire tab with the blue, white, black, and red wires to detach the speakers from the motherboard.
Place your fingers on the two metal tabs on the edges of the RAM.
Push on the tabs in the opposite direction.
5 участников успешно повторили данное руководство.
2 Комментариев
Looking at the Dell service manual. You dont need to remove any screws, but only the keyboard, and if your careful you dont need to remove the ribbon cable. Its all in the service manual you can download free from Dell.
