Выберете то, что вам нужно
Remove the four phillips screws that attach the stand to the computer.
Tilt the stand up and out.
Remove the three screws that hold the hard drive cage to the chassis.
Slide the hard drive cage out slightly to access and remove the power and SATA cable.
Lift the hard drive cage out.
Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
Lift the hard drive cage off the hard drive.
Excellent guide, was a super easy swap. I put an SSD in it!!
Hey Just one question, is the HDD SATA 2 or SATA 3? Just wanted to know so I can purchase an SDD with the correct specification.
35 участников успешно повторили данное руководство.
3 Комментариев
Thanks for this info this is very useful
Thank you once again
Really useful information thank you.
