Введение
Replacing the display is difficult because there are delicate cables that need to be manipulated.
Инструменты
Запчасти
Flip laptop right side up and open
Insert flat side of spudger gently along inside of screen and screen surround.
Work your way around the screen carefully releasing the screen surround from the lid.
Unplug the cable from the camera.
Unscrew the six screws attaching the display support frame to the laptop lid. Lower lid to desk.
When reassembling, plug the cable to the camera first, then screw in the lid.
Unplug the cable from the display.
The plug is held in on the sides with two clips. Gently pull on the each side of the cable to remove it from its connector.
Unscrew display from display hinge/support bracket. There are two screws on each side.
Unscrew the bottom screws first.
Unscrew the top screws while holding onto the screen with your other hand so it doesn't fall.
6 участников успешно повторили данное руководство.
4 Comments
i cant figure out how to take off the cable to the display help
in step 4
jhgfds
This should be listed as "easy", and time taken around 10-15 minutes.
Agreed should be labeled easier. 10-15 minutes
