Dell Inspiron n5050 Display Replacement
Выберете то, что вам нужно
  1. Dell Inspiron n5050 Display Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Display Replacement: шаг 2, изображение 1 из 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Display Replacement: шаг 3, изображение 1 из 2 Dell Inspiron n5050 Display Replacement: шаг 3, изображение 2 из 2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Display Replacement, Display: шаг 4, изображение 1 из 1
    • Flip laptop right side up and open
    • Insert flat side of spudger gently along inside of screen and screen surround.
    • Work your way around the screen carefully releasing the screen surround from the lid.
    • The screen surround is held in place by delicate plastic clips, so don't use too much force.
  5. Dell Inspiron n5050 Display Replacement: шаг 5, изображение 1 из 1
    • Unplug the cable from the camera.
    • Unscrew the six screws attaching the display support frame to the laptop lid. Lower lid to desk.
    • The lid still has the WIFI antenna connected to it.
    • When reassembling, plug the cable to the camera first, then screw in the lid.
  6. Dell Inspiron n5050 Display Replacement: шаг 6, изображение 1 из 3 Dell Inspiron n5050 Display Replacement: шаг 6, изображение 2 из 3 Dell Inspiron n5050 Display Replacement: шаг 6, изображение 3 из 3
    • Unplug the cable from the display.
    • This cable has delicate wires that can easily break. It is glued to the back of the display, but can be carefully peeled away.
    • The plug is held in on the sides with two clips. Gently pull on the each side of the cable to remove it from its connector.
  7. Dell Inspiron n5050 Display Replacement: шаг 7, изображение 1 из 2 Dell Inspiron n5050 Display Replacement: шаг 7, изображение 2 из 2
    • For this part, it is easiest to use a magnetized screw driver.
    • Unscrew display from display hinge/support bracket. There are two screws on each side.
    • Unscrew the bottom screws first.
    • Unscrew the top screws while holding onto the screen with your other hand so it doesn't fall.
Заключение
6 человек успешно провели ремонт по этому руководству.
Tyler
Участник с: 06/19/12
5 031 Репутация
Автор 16 руководств
Команду
TechForce Участник TechForce
Business
2 членов
Автор 29 руководств
4Комментарии к руководству
i cant figure out how to take off the cable to the display help
timothyamorrison - Ответить
This should be listed as "easy", and time taken around 10-15 minutes.
Paul Freeman-Powell - Ответить
Agreed should be labeled easier. 10-15 minutes
Jake Fisher - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 10
За последние 30 дней: 34
За всё время: 10,654
