Dell Inspiron n5050 Keyboard Replacement
Выберете то, что вам нужно
  1. Careful: steps 1-3 are sourced from a guide that's marked as in-progress.
    Dell Inspiron n5050 Keyboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Keyboard Replacement: шаг 2, изображение 1 из 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Keyboard Replacement: шаг 3, изображение 1 из 2 Dell Inspiron n5050 Keyboard Replacement: шаг 3, изображение 2 из 2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Keyboard Replacement, Keyboard: шаг 4, изображение 1 из 2 Dell Inspiron n5050 Keyboard Replacement, Keyboard: шаг 4, изображение 2 из 2
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 Keyboard Replacement: шаг 5, изображение 1 из 3 Dell Inspiron n5050 Keyboard Replacement: шаг 5, изображение 2 из 3 Dell Inspiron n5050 Keyboard Replacement: шаг 5, изображение 3 из 3
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
    What do I do is i broke the cable retainer wings and the black thing?
    Wezley Joao Ferreira - Ответить
    If the connector on the motherboard is still attached and only the clip is broken you can try and find a new clip, or perhaps tape the keyboard in place with electrical tape.
    Tyler - Ответить
    I didn’t need to disconnect and remove the cable. I simply set the keyboard gently to the side. This gave me full access to the two RAM module slots for replacement. Hopefully this will make the procedure easier.
    Clemmitt Sigler - Ответить
Заключение
4 участников успешно повторили данное руководство.
Tyler
Участник с: 06/19/12
4 920 Репутация
Автор 16 руководств
Команда
TechForce Участник TechForce
Business
2 членов
Автор 25 руководств
4 Комментариев
dis has realy helped me sir... love you!
jovialcom - Ответить
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
https://youtu.be/3c5P0pJgckg
mohamed - Ответить
Here’s a video guide to replacing the keyboard on this (or similar) laptop: https://www.youtube.com/watch?v=6T3xgkC-...
Paul Freeman-Powell - Ответить
My keyboard is not have a clips what i do?
BurIsm - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 10
За всё время: 9,822
