Введение
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
Выберете то, что вам нужно
Шаг 1 Battery
Careful: steps 1-3 are sourced from a guide that's marked as in-progress.
Flip your laptop over to view the bottom and locate the two locks.
Flip the laptop right side up. Open the laptop.
Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
Gently flip the data cable latch away from the data cable with flat side of spudger.
Lift the cable up and out.
When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
What do I do is i broke the cable retainer wings and the black thing?
I didn’t need to disconnect and remove the cable. I simply set the keyboard gently to the side. This gave me full access to the two RAM module slots for replacement. Hopefully this will make the procedure easier.
4 участников успешно повторили данное руководство.
4 Комментариев
Dell Inspiron 15 - M5040 N5040 N5050 disassembly
Here’s a video guide to replacing the keyboard on this (or similar) laptop: https://www.youtube.com/watch?v=6T3xgkC-...
