Введение
In this guide, we will be showing you how to remove and replace the Display Assembly.
Выберете то, что вам нужно
Remove the two screws that secure the display assembly to the computer base.
Disconnect the display cable and touch-screen cable from the system-board connectors.
Note the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
Remove the four screws that secure the display assembly to the computer base.
Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
Connect the display cable and touch-screen cable to the connectors on the system board.
Replace the two screws that secure the display assembly to the computer base.
3 участников успешно повторили данное руководство.
