Введение
In this guide, we will be showing you how to remove and replace the Hard Drive.
Выберете то, что вам нужно
Remove the two screws that secure the hard-drive assembly to the system board.
Slide the hard-drive assembly to disconnect it from the system-board connector.
Lift the hard-drive assembly off the system board.
Remove the four screws that secure the hard drive to the hard-drive bracket.
Replace the four screws that secure the hard drive to the hard-drive bracket.
Place the hard-drive assembly on the system board.
Slide the hard-drive assembly to connect it to the system-board connector.
Replace the two screws that secure the hard-drive assembly to the system-board.
3 участников успешно повторили данное руководство.
