Dell Inspiron n5110 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Inspiron n5110 Hard Drive Replacement, Remove the Screws: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron n5110 Hard Drive Replacement, Sliding the Hard Drive Assembly: шаг 2, изображение 1 из 1
    • Slide the hard-drive assembly to disconnect it from the system-board connector.
  3. Dell Inspiron n5110 Hard Drive Replacement, Lifting the Hard-Drive Assembly: шаг 3, изображение 1 из 1
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron n5110 Hard Drive Replacement, Remove the Screws: шаг 4, изображение 1 из 1
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  5. Dell Inspiron n5110 Hard Drive Replacement, Lifting the Hard Drive: шаг 5, изображение 1 из 1
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron n5110 Hard Drive Replacement, Placing the Hard Drive: шаг 6, изображение 1 из 1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron n5110 Hard Drive Replacement, Replace the Screws: шаг 7, изображение 1 из 1
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  8. Dell Inspiron n5110 Hard Drive Replacement, Placing the Hard-Drive Assembly: шаг 8, изображение 1 из 1
    • Place the hard-drive assembly on the system board.
  9. Dell Inspiron n5110 Hard Drive Replacement, Sliding the Hard-Drive Assembly: шаг 9, изображение 1 из 1
    • Slide the hard-drive assembly to connect it to the system-board connector.
  10. Dell Inspiron n5110 Hard Drive Replacement, Replace the Screws: шаг 10, изображение 1 из 1
    • Replace the two screws that secure the hard-drive assembly to the system-board.
Финишная черта
3 участников успешно повторили данное руководство.
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 985 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 9
За последние 30 дней: 52
За всё время: 2,950
