Введение
This guide will provide a step by step guide to remove the battery from the tablet. This is necessary for a device which has a faulty, broken, or a worn out battery.
Выберете то, что вам нужно
Place tablet face-down on flat surface.
Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
With the blue opening tool, gently lift up and remove the battery from the tablet.
4 участников успешно повторили данное руководство.
Один комментарий
I found that the down volume control was jammed by the case. So be careful with the reassembly around the volume control.
