Введение
This guide will provide a step by step guide to removing the motherboard from the tablet. This is necessary for any faulty or broken motherboards.
Выберете то, что вам нужно
Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
Remove the four 4.0mm black screws on the perimeter of the device using a JIS #00 screwdriver
Using an opening tool, lift upwards on the white clamp, and pull the blue tab out of the connection with tweezers.
Using tweezers, disconnect the white and black wires from the bottom of the motherboard.
Pull upwards while holding the brass connections. Do not pull on the wires.
Disconnect the two clamps, one orange and one white, using tweezers next to the battery.
With the blue opening tool, gently lift up and remove the battery from the tablet.
Rotate the motherboard upwards from the tablet using tweezers, but do not remove completely from the device. As you lift, disconnect the black and red wire located underneath the motherboard before removing it completely from the tablet.
Еще один человек закончил это руководство.
