Dell Latitude 5310 Battery Replacement
Выберете то, что вам нужно
  1. Dell Latitude 5310 Battery Replacement, open the back cover: шаг 1, изображение 1 из 3 Dell Latitude 5310 Battery Replacement, open the back cover: шаг 1, изображение 2 из 3 Dell Latitude 5310 Battery Replacement, open the back cover: шаг 1, изображение 3 из 3
    • place the laptop upside down on a soft, clean surface to avoid scratching
    • locate the screws (in this case 8)
    • use the screwdriver
    • 'Note: the screws are designe to stay attached in the back cover even after being unscrewed. This prevents loss.'
    • use the opening tool to open the back cover starting on the hinge areas. then move slowly around the edges
    • lift the open areas with your hand (lightly!) and slowly work using the tension along the edges.
  2. Dell Latitude 5310 Battery Replacement, remove the battery: шаг 2, изображение 1 из 2 Dell Latitude 5310 Battery Replacement, remove the battery: шаг 2, изображение 2 из 2
    • use the screwdriver to remove the screws which also stay attached
    • use your fingers to detach the battery connection cable from the motherboard
    • you can pick up the battery and take it out of the device
    • remove the connections cable from the "old" battery and insert to the new one
  3. Dell Latitude 5310 Battery Replacement, install new battery: шаг 3, изображение 1 из 2 Dell Latitude 5310 Battery Replacement, install new battery: шаг 3, изображение 2 из 2
    • insert the new battery and screw in
    • use the spudger to fix the connection cable then press with the flat of the spudger side to push it in
    • put the back cover on and use your palm to close softly
    • then screw the back cover back on
    • test if the device is working
    • Note: mostly the batterys are delivered empty so first you need to charge it maybe
    • its also possible to get the status of the battery: press F2 while starting to open bios settings then check battery status
Заключение
2 участников успешно повторили данное руководство.
Oliver Sandmaier
Участник с: 11/01/23
334 Репутация
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 25
За последние 30 дней: 82
За всё время: 457
