Dell Latitude 5480 Battery Replacement
Выберете то, что вам нужно
  1. Dell Latitude 5480 Battery Replacement, Opening the laptop: шаг 1, изображение 1 из 1
    • Start by loosening the 8 captive screws on the backplate. These screws will not come fully out of the backplate, so you can't lose them.
    • Pry the backplate off with a spudger or long fingernail. There is an opening marked by the orange arrow, but you can open it any way you see fit.
  2. Dell Latitude 5480 Battery Replacement, Removing the battery: шаг 2, изображение 1 из 2 Dell Latitude 5480 Battery Replacement, Removing the battery: шаг 2, изображение 2 из 2
    • Unplug the battery using the little plastic tab. This is marked with the blue rectangle.
    • Remove the screw to the right of the battery holding the battery frame in. There is only one on this model of laptop. It is marked by the red circle in picture two.
  3. Dell Latitude 5480 Battery Replacement, Reassembly: шаг 3, изображение 1 из 3 Dell Latitude 5480 Battery Replacement, Reassembly: шаг 3, изображение 2 из 3 Dell Latitude 5480 Battery Replacement, Reassembly: шаг 3, изображение 3 из 3
    • Remove the screw located at the top right corner of the battery, then the three additional screws located along the top of the battery.
    • Identify the battery connection cable, located at the top of the battery compartment.
    • Release the battery connection cable from its secured position.
Заключение
2 человек успешно провели ремонт по этому руководству.
Jordan
Участник с: 09/02/18
1 081 Репутация
Автор 4 руководств
2Комментарии к руководству
Thanks for this! It was super-simple, but I’m still grateful for the guide.
I got this computer used for my kids, and everything seemed to be going great until they let the battery drain completely. When that happens, the computer will no longer boot up until I open it up and physically disconnect the battery and then reconnect it. Once I do that, it works fine.
Any idea what I can do to keep from having it happen in the first place?
I’m running Ubuntu.
Thanks!
Lucas Weeks - Ответить
your CMOS battery may be dead or outdated logic board firmware. Try downloading the most current firmware for your logic board from Dell’s website- since you’re running Ubuntu you can’t use their Dell Command Update program to keep these updated.
Jordan -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 5
За последние 7 дней: 31
За последние 30 дней: 125
За всё время: 10,132
