Выберете то, что вам нужно
Remove the 9 phillips #0 screws from the bottom of the case.
Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
Once removed you will have access to the contents of your case.
Locate the solid-state drive.
Remove the screw on the right side of the drive.
After remove the screw, the drive will "pop-up" to approximately a 45% angle. Pull the drive straight out in accordance with the angle.
