Выберете то, что вам нужно
Remove the 9 phillips #0 screws from the bottom of the case.
Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
Once removed you will have access to the contents of your case.
Locate the wireless card.
Remove the one screw holding the card in using your PH0 bit.
Remove the bracket holding the wireless card in.
Remove the black and white wires from the wireless card.
