Dell Latitude 5580 Speakers Replacement
Выберете то, что вам нужно
  1. Dell Latitude 5580 Speakers Replacement, Lower Case: шаг 1, изображение 1 из 3 Dell Latitude 5580 Speakers Replacement, Lower Case: шаг 1, изображение 2 из 3 Dell Latitude 5580 Speakers Replacement, Lower Case: шаг 1, изображение 3 из 3
    • Orient your laptop so that you have access to the lower case, with the vents facing upwards.
    • Use a Phillips screwdriver to loosen the eight screws securing the bottom cover.
    • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
    • Insert the end of an iFixit opening tool or an opening pick into the seam between the bottom and top case to release the clips holding them together.
    • Slide the opening tool or pick around the edge of the laptop until the case is fully released.
    • Remove the lower case.
  2. Dell Latitude 5580 Speakers Replacement, Battery: шаг 2, изображение 1 из 3 Dell Latitude 5580 Speakers Replacement, Battery: шаг 2, изображение 2 из 3 Dell Latitude 5580 Speakers Replacement, Battery: шаг 2, изображение 3 из 3
    • Orient your laptop so that you have access to the bottom cover, with the fan vents facing upwards.
    • Use a Phillips #00 screwdriver to loosen the eight screws securing the bottom cover.
    • Insert the end of an iFixit opening tool or opening picks into the seam between the bottom and top case to release the clips holding them together.
    • Slide the opening tool or pick around the edge of the laptop until it is fully separated.
    • Remove the bottom cover.
  3. Dell Latitude 5580 Speakers Replacement: шаг 3, изображение 1 из 3 Dell Latitude 5580 Speakers Replacement: шаг 3, изображение 2 из 3 Dell Latitude 5580 Speakers Replacement: шаг 3, изображение 3 из 3
    • Remove the single Phillips #00 screw that is holding down the battery.
  4. Dell Latitude 5580 Speakers Replacement: шаг 4, изображение 1 из 2 Dell Latitude 5580 Speakers Replacement: шаг 4, изображение 2 из 2
    • Use the pull tab to gently pull the battery cable out of its socket.
  5. Dell Latitude 5580 Speakers Replacement: шаг 5, изображение 1 из 2 Dell Latitude 5580 Speakers Replacement: шаг 5, изображение 2 из 2
    • Remove the old battery.
    • To install the battery connection cable, push gently into the original connection port to connect the replacement battery to the computer. Tuck in the battery connection cable underneath the plastic frame next to the battery.
  6. Dell Latitude 5580 Speakers Replacement, Speakers: шаг 6, изображение 1 из 3 Dell Latitude 5580 Speakers Replacement, Speakers: шаг 6, изображение 2 из 3 Dell Latitude 5580 Speakers Replacement, Speakers: шаг 6, изображение 3 из 3
    • Use tweezers to unplug the wire connected to the hard drive, in the bottom left of the laptop.
  7. Dell Latitude 5580 Speakers Replacement: шаг 7, изображение 1 из 2 Dell Latitude 5580 Speakers Replacement: шаг 7, изображение 2 из 2
    • Unscrew the four 5.8 mm-long screws on the hard drive with a Phillips #1 screwdriver.
    • Lift the hard drive out of the laptop with your hands.
  8. Dell Latitude 5580 Speakers Replacement: шаг 8, изображение 1 из 2 Dell Latitude 5580 Speakers Replacement: шаг 8, изображение 2 из 2
    • Unscrew the three 3.4 mm-long screws securing the midframe with a Phillips #1 screwdriver.
    • Unscrew the two 5.8 mm-long screws securing the midframe with Phillips #1 screwdriver.
  9. Dell Latitude 5580 Speakers Replacement: шаг 9, изображение 1 из 3 Dell Latitude 5580 Speakers Replacement: шаг 9, изображение 2 из 3 Dell Latitude 5580 Speakers Replacement: шаг 9, изображение 3 из 3
    • Remove the midframe.
  10. Dell Latitude 5580 Speakers Replacement: шаг 10, изображение 1 из 3 Dell Latitude 5580 Speakers Replacement: шаг 10, изображение 2 из 3 Dell Latitude 5580 Speakers Replacement: шаг 10, изображение 3 из 3
    • Use tweezers to lift out the speakers in the bottom right of the laptop.
  11. Dell Latitude 5580 Speakers Replacement: шаг 11, изображение 1 из 3 Dell Latitude 5580 Speakers Replacement: шаг 11, изображение 2 из 3 Dell Latitude 5580 Speakers Replacement: шаг 11, изображение 3 из 3
    • Use tweezers to lift out the speakers in the bottom left of the laptop.
  12. Dell Latitude 5580 Speakers Replacement: шаг 12, изображение 1 из 2 Dell Latitude 5580 Speakers Replacement: шаг 12, изображение 2 из 2
    • Disconnect the speaker connector.
  13. Dell Latitude 5580 Speakers Replacement: шаг 13, изображение 1 из 2 Dell Latitude 5580 Speakers Replacement: шаг 13, изображение 2 из 2
    • Remove both the left and the right speakers along with the wire connected to them, with your hands.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Levi Dobkins
Участник с: 09/08/25
157 Репутация
1 руководство автора
Команда
University of North Texas, Team 3-1, Coppersmith Fall 2025 Участник University of North Texas, Team 3-1, Coppersmith Fall 2025
UNT-COPPERSMITH-F25S3G1
5 членов
Автор 4 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 116
