Dell Latitude 7480 Battery Replacement
Выберете то, что вам нужно
  1. Dell Latitude 7480  Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Make sure laptop is unplugged and powered off.
  2. Dell Latitude 7480  Battery Replacement, Remove the back cover: шаг 2, изображение 1 из 2 Dell Latitude 7480  Battery Replacement, Remove the back cover: шаг 2, изображение 2 из 2
    • Use a Phillips screwdriver to remove the eight screws securing the back cover.
    • Remove the back cover.
  3. Dell Latitude 7480  Battery Replacement, Unscrew the battery: шаг 3, изображение 1 из 2 Dell Latitude 7480  Battery Replacement, Unscrew the battery: шаг 3, изображение 2 из 2
    • Use a Phillips screwdriver to remove the two screws securing the battery in place.
    • Carefully peel the tape holding the battery cable in place.
    • Be careful not to puncture the battery.
  4. Dell Latitude 7480  Battery Replacement, Disconnect the battery cable: шаг 4, изображение 1 из 3 Dell Latitude 7480  Battery Replacement, Disconnect the battery cable: шаг 4, изображение 2 из 3 Dell Latitude 7480  Battery Replacement, Disconnect the battery cable: шаг 4, изображение 3 из 3
    • Using the pull tabs pull up and remove the battery connector from the motherboard.
    • Remove the battery and set aside to remove the connector cable.
    • If your new battery did not come with a connector cable you will need this.
    • Remove the connector cable. Set aside to apply to the new battery.
  5. Dell Latitude 7480  Battery Replacement, Install the battery cable: шаг 5, изображение 1 из 2 Dell Latitude 7480  Battery Replacement, Install the battery cable: шаг 5, изображение 2 из 2
    • Connect the battery cable to the new battery. You can skip this step if your new battery came with one installed.
    • Connect one end of the battery cord to the battery. Route the cord in the channel between battery cells.
  6. Dell Latitude 7480  Battery Replacement, Install the new battery and test: шаг 6, изображение 1 из 2 Dell Latitude 7480  Battery Replacement, Install the new battery and test: шаг 6, изображение 2 из 2
    • Install the new battery by doing the steps in reverse. Be sure to test the device with and without AC power applied to the laptop.
    • Dispose of old battery properly and safely.
Заключение
21 участников успешно повторили данное руководство.
brandon bradshaw
Участник с: 08/21/17
658 Репутация
1 руководство автора
Команда
Kyber Computer Solutions LLC Участник Kyber Computer Solutions LLC
Business
1 член
Автор 7 руководств
2 Комментариев
Thank you!
Didn’t need the entire teardown, just the batter Watt-hour and general shape to make sure I am buying the correct thing.
Keep up the great work for the community.
jeff5496 - Ответить
It would also be helpful if you included the specification of the screws. For example, if you buy one without a battery.
omanoman - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 11
За последние 7 дней: 109
За последние 30 дней: 421
За всё время: 41,561
