Введение
Use this guide to replace the coin cell battery (CMOS) of the Dell Latitude 9410 2-in-1.
If your computer runs slow, receives “Booting Error” messages, or loses BIOS settings when turned off, the CMOS may need to be replaced. The typical CMOS lifespan is 3-5 years, so if you're experiencing issues related to a failing CMOS, it's likely time to replace it. Be sure to check the troubleshooting page before moving forward with replacement.
Выберете то, что вам нужно
Carefully peel back and remove the black tape around the top left corner of the motherboard.
Инструмент, используемый на этом этапе:Tweezers$4.99
Grip the CMOS cable as close as possible to the plug, and gently pull directly backwards, in the direction of the cables, until the CMOS cable disconnects from the motherboard.
