Введение
Use this guide to replace the display of the Dell Latitude 9410 2-in-1. Screen abnormalities such as flickering, horizontal or vertical lines, or color fades may indicate a faulty display.
Выберете то, что вам нужно
Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
Carefully detach the ribbon that is affixed to the HDD.
Using a Philips #00 screwdriver, unscrew the 3, top left and top right 4mm screws located about the hinge.
