Введение
Not much prior knowledge is required before starting. According to Dell, however, you must have the following tools:
"‡#0 and #1 magnetized Phillips-head screwdrivers
‡ Small flat-blade screwdriver
‡ 5-mm socket wrench
‡ 7-mm socket wrench
‡ Small plastic scribe"
(Guide found at: http://tim.id.au/laptops/dell/latitude%2...)
  1. Flip laptop over. Flip laptop over.
    • Flip laptop over.
  2. Remove the screws over the RAM door Remove the screws over the RAM door
    • Remove the screws over the RAM door
  3. iPhone Battery Fix Kits
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Open the RAM door. Open the RAM door.
    • Open the RAM door.
  5. Carefully pull the tabs over the RAM chip down - the RAM will spring up. Carefully pull the tabs over the RAM chip down - the RAM will spring up.
    • Carefully pull the tabs over the RAM chip down - the RAM will spring up.
  6. Remove the RAM from the socket and insert replacement RAM.
    • Remove the RAM from the socket and insert replacement RAM.
Заключение
3 участников успешно повторили данное руководство.
Axuak
Участник с: 04.05.2011
331 Репутация
Автор 2 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 2,074
