Инструменты
Запчасти
Детали не указаны.
1. unplug laptop
2. remove battery
3. remove screw
Remove disk drive by pressing in the pull mechanism, causing it to extend outwards, then use the pull handle to pull out disk drive.
open laptop
with a small screwdriver carefully pry plastic cover
be careful not to break these clips
The clips found under here were specially tricky
remove screws X 2
carefully lift keyboard, being careful not to damage the flat cable.
lift up tab to release flat cable and remove keyboard
disconnect the three wires
disconnect video connector
remove ground screw
remove 3 screws
remove last screw, note this screw is longer then the other three
remove screen
Remove these 15 screws, they are all the same size
remove screw and cover
flip the laptop over
remove touchpad flat cable by gently pulling up.
remove 4 screws marked with the letter P
remove 3 screws
carefully remove small metal piece that was being help down by the three screws
remove 4 screws
remove 1 screw
being careful not to break any clips, separate bottom plastic cover from the mother board carriage.
The middle part of my power connector had sheared away from its solder points on the motherboard.
I had to use a bit of flux, but I managed to re-tin all three contact point on the motherboard, as well as the pins in the connector.
I re-soldered the whole thing and used my trusty hot glue gun to encase the whole connector to prevent it from happening again anytime soon.
6 участников успешно повторили данное руководство.
