Запчасти
No parts specified.
  1. Remove the 6 screws underneath the rubber things - located in red
    • Remove the 6 screws underneath the rubber things - located in red
  2. Use your spudger to pry off the front case Go all around the perimeter and pop it off
    • Use your spudger to pry off the front case
    • Go all around the perimeter and pop it off
  3. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  4. Remove the 6 screws holding in the display screen
    • Remove the 6 screws holding in the display screen
  5. Remove the screw holding in the display cable conenctor Pull the black tab up to remove the display cable connector Pull the black tab up to remove the display cable connector
    • Remove the screw holding in the display cable conenctor
    • Pull the black tab up to remove the display cable connector
  6. Slowly Remove the wire from the joints holding it in
    • Slowly Remove the wire from the joints holding it in
  7. The computer is happy you are fixing him Thats it, display is now removed feel free to replace it by doing the steps in reverse
    • The computer is happy you are fixing him
    • Thats it, display is now removed feel free to replace it by doing the steps in reverse
Заключение
Joseph
Участник с: 16.07.2014
1 427 Репутация
Автор 5 руководств
Один комментарий
I see you removed the keyboard by seeing it in the background of the last image however, I do not see the steps instructing everyone on how to remove the keyboard.
Darren - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 3
За 30 дней: 11
За всё время: 1,440
