Введение
Guide to separating the display from the body of the laptop.
Выберете то, что вам нужно
Locate the notch under the cover at the top of the keyboard
Using the spudger as a lever, lift the plastic covering
Carefully remove the rest of the covering from right to left
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
Close the laptop lid
Turn the laptop over onto its backside
Unscrew the two screws shown in the picture using a #00 screwdriver
Face the laptop's back ports towards you
Unscrew the two screws labeled in the picture using a #00 screwdriver
Turn the laptop over again so it's right-side up
Open the display, and pull the display up and out of the laptop's body
Unscrew the screws that were under the rubber circles using the #00 screwdriver
Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
19 участников успешно повторили данное руководство.
Один комментарий
Check out this replacement screen at a great price on bcdelectrostore.com
Please help me
manaqib arif - Ответить
Mera display ka masla hai
