Введение
Introduction
Ram is your laptops temporary memory and can be replaced if damaged or you can upgrade it. This will help run more programs or make the ones you run faster and more efficient.
This Guide Will Teach You
  1. Where the ram is located
  2. How to remove safely
  3. Tools needed to complete the replacement
Запчасти
Никакие детали не требуются.
  1. Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Using two index fingers, slide the battery latches outward.
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your story with #ImAGenius for a chance to win $100!
    We Are All Geniuses
    Share your repair story with #ImAGenius
  4. Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
    • Locate and unscrew the captive screw indicated in the picture on the left to detach the panel.
  5. Use your fingers to push out the latches holding the RAM in place.
    • Use your fingers to push out the latches holding the RAM in place.
    • The RAM should now sit up at an angle so you can safely remove it.
Заключение
To install the new RAM, set it in the slot at an angle and push it in until the latches reclick.
11 участников успешно повторили данное руководство.
Jon Amireh
Участник с: 17.01.2013
1 370 Репутация
Автор 8 руководств
Команда
Cal Poly, Team 6-1, Johann Winter 2013 Member of Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
4 членов
Автор 9 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 1
За 7 дней: 3
За 30 дней: 28
За всё время: 4,947
