Выберете то, что вам нужно
Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
Place thumbs flat on the front side of the back panel (the side to open the laptop).
Push panel upwards sliding it out of the locked position.
Lift panel out of socket.
Remove panel and screw from the device. This opens up the main board of the device.
Once you removed the back panel, the RAM will easily be located.
Place your thumbs on each side of the RAM tabs.
Gently push outward on the tabs to release the RAM. This will allow you to remove the RAM completely from your device.
Еще один человек закончил это руководство.
