Dell Latitude E4300 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Latitude E4300 Hard Drive Replacement, Keyboard: шаг 1, изображение 1 из 1
    • Open the laptop and remove the small panel located above the keyboard.
  2. Dell Latitude E4300 Hard Drive Replacement: шаг 2, изображение 1 из 1
    • Using a Phillips 1 Screwdriver, unscrew the three M2x3-mm screws located above the keyboard where the small panel was originally.
  3. Dell Latitude E4300 Hard Drive Replacement: шаг 3, изображение 1 из 1
    • Pull off keyboard forward and then outwards.
    • The keyboard is fragile, so make sure you pull the keyboard off carefully.
  4. Dell Latitude E4300 Hard Drive Replacement, Keyboard Docking Component: шаг 4, изображение 1 из 1
    • With your Phillips 1 screwdriver, unscrew the five M2.5x5-mm screws and the five M2.5x8-mm screws that lie underneath the keyboard panel.
    • Be aware there are two deeply recessed screws on both sides to the rear of this panel. There are also two screws externally on the rear face either side of the battery that hold the monitor on and pass through this panel, support the screen when you remove these. There are also two screws above the hard drive bay that need to be removed.
  5. Dell Latitude E4300 Hard Drive Replacement: шаг 5, изображение 1 из 2 Dell Latitude E4300 Hard Drive Replacement: шаг 5, изображение 2 из 2
    • Remove additional wires located within the panel.
    • For the smaller wires, try using a spudger for easier access.
  6. Dell Latitude E4300 Hard Drive Replacement: шаг 6, изображение 1 из 1
    • Lift the keyboard panel to separate the component from the rest of the device.
  7. Dell Latitude E4300 Hard Drive Replacement, Hard Drive: шаг 7, изображение 1 из 2 Dell Latitude E4300 Hard Drive Replacement, Hard Drive: шаг 7, изображение 2 из 2
    • Unscrew the three screws located on the top of the component.
    • Lift the hard drive out of its holding in an outward motion and remove it from the device.
Заключение
Ryan Blakey
Участник с: 09/24/18
172 Репутация
Автор 2 руководств
Команда
University of North Texas, Team S6-G5, Thompson Fall 2018 Участник University of North Texas, Team S6-G5, Thompson Fall 2018
UNT-THOMPSON-F18S6G5
4 членов
Автор 5 руководств
3 Комментариев
What!?! You can simple remove the hard drive by undoing two screws on the bottom of the laptop. Then you can remove the bezel from the laptop by undoing one more screw. It’s detailed in the service manual on the Dell website.
Rob Walter - Ответить
I agree with Rob. It’s been made very easy. Pretty much the same as model E4310 here Dell Latitude E4310 Hard Drive Replacement.
Gwenole Capp - Ответить
OK well, there’s no any need for such a BIG job actually! :)
Tarmo Tuljak - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 1,398
