Введение
This guide walks through how to remove and replace a display on the Dell Latitude E4310 laptop in the event of a broken or bad display.
Выберете то, что вам нужно
Push in the battery release button with your thumb.
Pull up on the battery to remove.
Open up the laptop and flatten it down on a workable surface.
Turn it around so that the screen is closest to you.
Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
Remove the bezel.
Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
5 участников успешно повторили данное руководство.
