Выберете то, что вам нужно
Be sure to remove the battery to prevent any electrical shortage.
Losen all four screws and remove the backpanel.
Remove the backpanel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
Now you can upgrade or change the memory.
NOTE: If the laptop doesnt boot after the upgrade, make sure the ram is fully inserted. Still doesnt boot? Try another memory stick.
Еще один человек закончил это руководство.
