Dell Latitude E5450-5450 Wifi Card Replacement
Выберете то, что вам нужно
  1. Dell Latitude E5450-5450 Wifi Card Replacement, Wifi Card: шаг 1, изображение 1 из 1
    • Remove the 6 screws using a Philips #1 (PH1) screwdriver.
  2. Dell Latitude E5450-5450 Wifi Card Replacement: шаг 2, изображение 1 из 1
    • Using your fingers or a pry tool, gently lift the cover from the device. If the device has been opened before, it should open easily from the top corner using your finger.
    • If it is a tight fit, a spudger can be used to gently pry open the cover. Place the spudger at the top corner to pry open.
  3. Dell Latitude E5450-5450 Wifi Card Replacement: шаг 3, изображение 1 из 1
    • Disconnect the battery before proceeding to reduce the risk of shock or damage.
    • Gently pull the tab attached to the battery to disconnect it.
  4. Dell Latitude E5450-5450 Wifi Card Replacement: шаг 4, изображение 1 из 1
    • If the wires are not clearly labeled as 1 and 2, take note of how the wires are connected to know which is 1 and 2. The WiFi card should have a tiny 1 and 2 on the card itself for guidance.
  5. Dell Latitude E5450-5450 Wifi Card Replacement: шаг 5, изображение 1 из 1
    • Use a Philips #1 (PH1) screwdriver to remove the screw holding the WiFi card in place.
  6. Dell Latitude E5450-5450 Wifi Card Replacement: шаг 6, изображение 1 из 1
    • Gently disconnect the antennas and slide the WiFi card from the slot
    • Slide new WiFi card into the slot and reassemble the device by completing steps 1-6 in reverse order.
    • You might need to use tweezers to hold the cables in place as you connect the antenna to the WiFi card. A spudger can be used to gently press the connectors into place.
Заключение
Jeannie Crowley
Участник с: 07/14/15
459 Репутация
Автор 2 руководств
Команда
Ethical Culture Fieldston School Участник Ethical Culture Fieldston School
Business
3 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 22
За всё время: 908
