Dell Latitude E5470 LC-Display Panel Replacement
Выберете то, что вам нужно
  1. Dell Latitude E5470 LC-Display Panel Replacement, Bottom cover removal: шаг 1, изображение 1 из 2 Dell Latitude E5470 LC-Display Panel Replacement, Bottom cover removal: шаг 1, изображение 2 из 2
    • Loosen the 8 screws on the bottom cover. The screws will remain in the casing, they do not come out all the way.
    • Insert the pick or spudger between the upper and lower casing to release the plastic clips.
    • Attention needed: The clips are easily broken.
  2. Dell Latitude E5470 LC-Display Panel Replacement, Disconnect the battery: шаг 2, изображение 1 из 1
    • To disconnect the battery, pull gently upwards on the tab connector.
  3. Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Bezel: шаг 3, изображение 1 из 1
    • Using a pick or spudger, gently insert between the LCD back-cover and bezel to release the clips.
    • The bezel is also glued to the LCD panel.
    • Remove slowly to avoid tearing or damaging any components underneath.
  4. Dell Latitude E5470 LC-Display Panel Replacement, Removing the LCD panel: шаг 4, изображение 1 из 1
    • Remove the 4 Philips screws securing the panel.
  5. Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: шаг 5, изображение 1 из 3 Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: шаг 5, изображение 2 из 3 Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: шаг 5, изображение 3 из 3
    • Remove the LCD paneland lay it flat on the keyboard.
    • You will be able to see the connector on the back of the LCD panel secured with some adhesive tape and a metal connector.
    • Udsing the tweezers, slowly lift the tape away to reveal the blue sticky protector. Removing the blue pad to see the metal connector underneath.
    • Using a spudger, lift the front of the connector up (highlighted by the white arrow).
    • Pull the cable back to release the cable from the connector.
    • To reassemble, follow the steps in reverse.
Заключение
4 участников успешно повторили данное руководство.
Harvey
Участник с: 02/15/16
5 193 Репутация
Автор 10 руководств
5 Комментариев
Your presentation is perfect
sachida1986niit - Ответить
Hello, will this model with touch screen work with non touch replacement LCD?
cellularcircuit - Ответить
Damaged touch lcd and was not using touch , want to save some $ by installing not touch lcd..
cellularcircuit -
Thanks - seems that little piece of blue sticky protector was my whole problem, months of a flickering screen, that was temporarily fixed upon pressing on the bottom of the bezel. Upon opening up the screen, it was crooked. So I straightened it, put things back together, and the flickering seems to be gone. Cross my fingers!
Peter Lyons - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 46
За всё время: 8,484
