Введение
If the user would like to replace a faulty Bluetooth card, or one that is not powerful enough, this guide will give step by step information on how to achieve this.
Выберете то, что вам нужно
Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
Place your hands on the plate and pull it toward yourself.
The plate will pop out of place and may then be removed.
The Bluetooth card is located near the front of the device, and is the expansion card with one antenna attached to it.
4 участников успешно повторили данное руководство.
